"shudder" can be cause by 5 issues:
1) hot spots or warped flywheel. get the flywheel turned and you're good.
2) worn clutch disc. difficult to measure, cheap to replace.
3) worn or warped pressure plate "fingers". also cheap to replace.
4) bad throw-out bearing or bearing collar. if the throwout bearing is loose on the collar then replace them both.
5) worn or cracked transmission front bearing retainer. this is the part that the throw-out bearing rides on. if there's excessive wear or it's cracked, then the retainer needs to be replaced.
since you already have the trans out, do yourself a favor and get hne flywheel resurfaced and replace the entire clutch assy. even though the disc looks like it's got some life left in it, you're better off replacing them all at this point. so get a new disc, pressure plate, throw-out and pilot bearing.
if you're not sure how to do the job properly, go to the dealer and buy the FSM for your rig. it'll pay for itself the first time you open it.
hth
georg @ valley hybrids
good point and reason #6 for chatter:
oil contamination. usually goes along with a nasty burning oil smell and definetly not the cause for the shudder issues with the clutch pictured above.
Georg,
Don't forget about #7 the PO re-surfaced the flywheel with an angle grinder.
I just went through this whole process 2 weeks ago. Do yourself a favor and do it right the first time, you do not want to do it twice. All the above posts nailed it for you.
Good luck
you're right tony. so we might as well keep going:
#8 loose flywheel or pressure plate bolts.
#9 mis-adjusted or loose pressure plate finger adjusters. this applies only to the three finger clutches likt the one pictured at the top of this thread. refer to the fsm for proper adjustment.
#10 broken engine mount(s) always check these first.
#11 loose clutch fork pivot or pivot bolt
#12 worn clutch fork or fork pivot
#13 do i need to keep going?!![]()
I had a " shutter " when releasing the clutch and i pulled the tranny & t case tonight. This is what came out. do i need a new clutch and pressure plate? Maybe just a new disc ? maybe all new and re face the flywheel?
