Good feedback @Taco2Cruiser
that is what I would have thought adjusting the front spring rate and modifying a standard swaybar if it was needed would work fine for my needs when the KDSS retires.
I'd just be cautious of taking action before it was needed, to each their own. From my experience KDSS helps on off camber situations by keeping tires contacted to the ground by allowing more droop which assists in stabilizing the truck. That's like droop with hydraulic force backing it. Even if you figure out a way to fashion the alternative sway bar to be a quick disconnect you're going to loose out on that stability aspect and the stability aspect is nice with such a heavy and tall rig - tall because if you need room for larger tires, which is most of the limit we bitch about with KDSS, then you probably are lifting it a good amount, raising the CG. What the school of though on that?
I'm not sure what you'd call it but if you've ever turned the KDSS screws while an LC is on a lift (at least 2 wheels off the ground) you'll notice that when you hit a certain point the wheels in the air will drop several inches.I know this is an old post. But in regards to KDSS actively pushing down on the drooping wheel with hydraulic inputs - I don't believe this is true. KDSS only has the ability to create roll stiffness. And to relax any roll resistance. It does not impart additional articulation. Best it can do is simulate almost no roll bar at all.
Which suggests KDSS is preventing those tires contacting the ground with as much force?I'm not sure what you'd call it but if you've ever turned the KDSS screws while an LC is on a lift (at least 2 wheels off the ground) you'll notice that when you hit a certain point the wheels in the air will drop several inches.
Would someone with an LX measure the diameter of their sway bars? I’m curious how they compare to those on a KDSS equipped cruiser.
Actually, the LX doesn't have a front sway bar at all.
Are you sure about that? Curt implies the front bar bolts up to a LC and there is definitely a bar, brackets, and end links in the EPC.. for a 2009LX anyway. I didn’t check other years.
I stand corrected. Peaked underneath and it's a pretty big bar staring right back at me. Measured 34mm.
You'll be able to ask the guy narrating the video all about KDSS in exactly one week.
Let me know if you decide to do the swap, I'm not far away and would be glad to help turn wrenches, or hang out and talk cruisers.Under the truck this weekend, and man... I'm dreading the day those KDSS lines fail... Located in VT, and even with periodic FluidFilm application, I'm seeing quite a bit of cancer developing on the lines.
And yea, what they said above! Update us please!
