Disc Brakes
I finally got around to bleeding the brakes on my FJ and I noticed the pedal travel is a bit to much for my liking when hte FJ is not running.
Heres my current setup.
Fj 60 front brakes
FJ80 1 inch bore master(Marlin crawler non abs FJ80)
TSM brackets and chevy small calipers
Mini truck booster
adj proportioning valve.
IS there a way to increase the pedal travel? or do you think a 2lb residual valve will need to be added front and rear?
I currently run a wilwood gas pedal which sits about 3 inchs from the floor and the brake pedal is about level if not alittle below that pedal when fully pressed and hte motor not running.
