Digital Clock replacement
Outsane
Supporting Vendor
San Mateo, CA
Website
solvefunction.com
I made a clock replacement for the 70 series.
This adds a
GPS speedometer
Time, date
Altimeter
Voltage
And lots of other features
Only needs to be connected to power that used to go to the clock.
This is installed on a 80 series, electrical untis is the same.
Untit only needs power and ground for these functions
In!
Hey. You seem to be pretty deep into the 3D printing thing. Consider making a plug to fill the gaping hole when you convert E hubs to manual?
@sleepydad69 made some for his project. I don't think it's something he plans to produce for dollars. Maybe some plan file sharing for the betterment of the automagic hub community.
See Builds - 1997 HZJ77HV-PEU Build (Grey Poupon) - https://forum.ih8mud.com/threads/1997-hzj77hv-peu-build-grey-poupon.1299043/post-14829537
@Outsane
I think maybe I have a set left... pretty sure I have the .STL files laying around someplace.
for ref
I think I used this stuff... was using for another bushing project so I just used the extra
let me see what I still have laying around
@sleepydad69 I do the same and try to keep learning. I will probably take your model and add a little bit so they squish for a good seal. From the picture I saw it looked pretty flush.
I will make them in Tpu with a hardness of 95. It's a very tough material.
What an awesome addition. Is it PnP or does it need to be tapped into a switched power circuit?
There's is a bracket that is included and needs to be screwed in as part of the assembly.
Yes tap into the acc power that would usually go to the clock. You can use spade terminals so you don't need to tap anything
