As part of my restoration I'm rebuilding the diffs. This includes installing an ARB locker in the rear. If you'd like to see the overall build check out the build thread linked in my sig. I'll have to post this in pieces.
I am not a professional mechanic. Please offer feedback and suggestions if you see something I could do better. Regardless, I try to be well prepared for tasks like this. I read a lot and ask a bunch of questions before starting.
First, I ordered everything from Cruiser Outfitters. This includes front and rear rebuild kits, plus the locker and compressor. I also bought knuckle kits and a whole bunch of other stuff, but this is about the diffs. The kits included preload and depth shims, bearings, gear marking paint, paint brush, pinion nut with integrated washer....everything really.
I've had a bunch of questions for @cruiseroutfit and they've always been quick with an answer. One issue that popped up I actually discovered while I was browsing their flange tech info page here: Cruiser Outfitters. I noticed I had course spline flanges(on an '81...) and that led me to finding out that a PO had rebuilt the diffs prior. But, I had all the right new parts regardless. I decided to keep the existing ratio.
For the job I recommend these tools:
- The factory service manuals. I couldn't imagine doing this without them.
- Mitutoyo .0001" dial indicator. I've read lots of people throw out numbers at .001" precision, but the factory service manual goes to .0001" on many recommended tolerances so I went with that.
- NOGA magnetic dial indicator base.
- Brass Drift
- Shop Press
- OTC 4520 Differential Side Bearing Puller Kit
- OTC 1123 Bearing Splitter (1/2" to 4-5/8").
- Micrometer
- Homemade jig for holding the diff in two positions. Flange up for checking pinion preload, and flange down for everything else.
- It was also very helpful to use the old bearings for pressing and hammering on the new ones.
- Beam-type inch-pound torque meter/wrench and adapters to size up to the pinion socket.
- Iphone... For pics - and slow-motion video of preload tests so you can snag the exact reading
