asutherland
VA7 HDT
Hey guys
Over the last few months I've been doing a lot of MUD and Google searches, but haven't found my exact problem. (or at least a thread with answers in it)
I know quite a few things -can- cause white smoke, so I'll list things I've tested, adjusted or replaced, as well as some that are still on the list.
First off, everyone loves specs and symptoms (except me, of course...)
Following are possibilities?
I've also been able to determine that the smoke coming out is definitely grey/white with a tinge of blue. I've been told by someone that knows more than me (lol) that this is UNBURNT diesel, likely from clogged or damaged injectors. Diesel that didn't spray out of the injectors in a fine mist and therefore didn't combust.
I will mention again that the smoke is MOST apparent when in a drive gear (ie. D, 2, 1, R...) and hardly noticeable at all when in N or P. Whether I'm in 4-low doesn't seem to have any affect on it either way.
- 1993 HDJ81 with 1HD-T with 178,000 kms
- Intermittent white smoke, could be slightly blue but the lighting can affect the way it looks
- When I first got the vehicle, it burned a lot of black smoke on accel. I played with the fuel screw and reduced it to the point of getting a tiny puff of black on first accel, but once turbo has spooled it doesn't burn black anymore.
- Usually on low loads, such as waiting at an intersection or crawling on the trail. Occurs more when in D (drive) or 1st and 2nd, dramatically reduced (to nearly nothing) when in Neutral and Park. 4-Low doesn't make a difference.
- Very intermittent, on a 30 min drive through the city, 3/4 of the stop lights it'll puff out smoke but 1/4 it won't. Not related to how long I've been driving for.
- No coolant leaks, and doesn't burn any coolant. Levels haven't changed at all.
- Burns about 1L oil in 10,000km
- EGTs post turbo seem normal, 300-600 F during normal operation and 900-1,000 on hills
- Fuel economy seems about normal from what others say. I get about 500-550km (not calculating for larger 315 tires) in city and 650-700 on highway
- Worse in cold whether (to be expected...) but doesn't get better when the engine is fully warm.
- Power seems normal. Does not stutter, have issues idling, or have issues starting - other than the 3 times listed below...
- 3 times since I bought the truck it would not start when cranking over. Cranking power was good, it really tried... but would not start until I used the "manual" IP pump and gave it 3 or 4 good pumps. One time this happened the truck sat for a week, the other time it only sat overnight.
- I have replaced air filter
- I have replaced the fuel filter.
- I have timed the IP to FSM specs (it was too far advanced)
- I have had the valve lash checked. Slightly out of spec (too loose) but nothing that would cause this
- I have tried injector cleaner, including the highly concentrated expensive BD stuff on a nearly empty tank
- I have removed the ACSD (prior to IP timing)
- I have installed a catch can exactly like LanceCruiser's in this thread: https://forum.ih8mud.com/diesel-tech-24-volts-systems/320050-thoughts-oil-catch-can.html
- I have NOT replaced / rebuilt injectors
- I have NOT had the compression tested
- Small amounts of air in the fuel line?
