Been reading a few threads about oil catch cans to collect the blow-by oil out of the crank case which get sucked in again through the air intake. for ex. this thread:
https://forum.ih8mud.com/diesel-tech-24-volts-systems/282728-catch-your-can.html
and this one:
https://forum.ih8mud.com/diesel-tech-24-volts-systems/300739-oil-catch-can-installed.html
It all make sense, but I have a concern: with the OEM setup, the oil fumes are actually being sucked out from the crank case by the vacuum action of the air intake. While if you use a catch can you will just collect the fumes through the can without any "positive" suction. Is it better to use an inline air/oil separator like what's used in compressors while painting cars. This way you can maintain the suction and collect the oil at the same time. Does such system exist or can be cheaply adapted?
Here's a picture of a Cosworth air/oil separator for inspiration..pretty costly at 115 GBP
Forge Motorsport | Alloy Fabrication
and this one:
