- Thread starter
- #21
Thank Daner , I did a lot of research before I started this project and still , but I have seen a few FJ40 like you did the problem with oil pan is the FJ40 axle is to far forward right where the oil pan is but unlike the pickup the oil pan is clean from the axle the only thing in the way is the steering control arm but that’s an easy fix , i think you can get away by raise the motor little higher but others they cut and shortened the oil pan by one inch .Looking forward to watching your build, and seeing what mods you do to get performance. I did a similar OM617 swap into an FJ40 with 85 Toyota running gear a few years ago. The biggest challenge was the oil pan clearance.
Its a big job but it looks like you are off to a good start
