Hey all,
I have a super annoying and very intermittent issue with our 2006 LX470- 130,000 miles.
This has only happened four times in the past year. Each time was a couple hundred miles from home, after driving for several hours, during very hot conditions and while pulling our small camper. The truck will either sputter and die when we are driving at slower speeds (fine at highway speeds) or won't start after turning it off. It will restart and run fine after letting it sit for a few minutes.
Thanks
- No codes
- Turns over just fine. Sounds like it's not getting fuel.
- Currently running at about 198 degrees, although it was having some near overheating issues last year during the first two instances
- Replaced the fuel pump
- Replaced the fuel filter
- Cleaned throttle body.
- Cleaned the mass airflow sensor
- Flushed and filled the radiator
- Replaced the fan clutch
- Replaced the thermostat
- The last time I unhooked the fuel line at the filter and fuel was spraying out
- Once it restarted after I smacked the carpet right where the fuel pump is but that might have been a coincidence (I had already replaced the fuel pump by this point)
- The first two times it sputtered, lost power and eventually died. Even under full gas it was barely moving. Of course, it died 30 feet from our campsite, blocking the whole road.
- The final two times it wouldn't restart after turning it off although it was running fine beforehand.
- Once the truck shuts down and only cranks, a very strong chemical is in the cabin. I *think* it's Feron. It does not smell like gas.
Thanks
