I didn’t have any CEL or codes. My symptoms were fuel smells in the cabin, and engine shut down during high ambient temperatures.I'm not getting any codes, is there any way to check whether charcoal canister is bad? Other than the expense, it looks like a rather easy fix.
"strong chemical smell"Hey everyone, thanks for all the input.
One additional clue I forgot to mention but will add to the original post.
Once the truck shuts down and only cranks, a very strong chemical is in the cabin. I *think* it's Feron. It does not smell like gas.
I plan to wrap the fuel lines this week. We're heading out on the 5th for the Tetons and Yellostone, so hopefully, that will help.
I'm apprehensive about replacing the charcoal canister due to the cost. Is there a way to test it?
Could OP remove charcoal canister and probably get a wiff of that old gas smell if he tested it?"strong chemical smell"
Likely the smell of old stall gas. Like gasoline left in a can for decades (putrefied). Good clue CC is loaded with old raw fuel and has been for a long time, is that strange smell. Saturated Charcoal Canisters (CC), just get worse with use. Heat like from OAT, engine & AT heat, trapped exhaust heat, radiant road heat, etc.. Results in expansion making condition worse.
At some point raw fuel enters CC. Either overfilling gas tank (03-07), engine run very hot for long time heating fuel (expanding). Drove up hill after topping fuel tank, on hot day, shanking full fuel tank on rocky road driving uphill, ect. Once raw fuel gets in CC, it staurates charcoal. The saturated charcoal then, can't keep up vapor flow and just keeps loading up. This result in excessive pressure in EVAP. Pressure = heat!
Correct issue that started CC staurating and then replace the CC. I use only OEM CC, based on the vehicle VIN#. In 06-07 I also replace the CC filter which is sold seperate.
If CC contaminated. It will be heavier than the new OEM one you install.
I've yet to see a DTC for bad CC.
forum.ih8mud.com
I think he got a wiff.Could OP remove charcoal canister and probably get a wiff of that old gas smell if he tested it?
What about removing the lines to the canister when the vehicle is experiencing the issue? If the issue goes away could that be a means of troubleshooting before replacing the CC?
Anything done to reduce fuel heat is a good thing, no doubt!I also have a 2006 LX and I've been dealing with this exact issue every summer since I bought the vehicle five years ago with 150,000 miles on it. The LX drives great all year but at least 2 - 4 times every summer, when the weather here in Las Vegas gets near 100F and higher, and I've been driving around town in the hot afternoon sun (3pm - 6pm), and I come to an idle (ie. engine is NOT under load), the engine will occasionally start to stumble and then stall. The LX is not overheating and there are no error codes, but I then have to wait between 10 - 30 minutes for the fuel to cool down before the engine will turn over, and then start back up and run without any problem.
A couple of summers ago, after it had happened at least a half dozen times over the prior couple of years, it finally did throw a CEL and I had to replace a catalytic converter. Shortly after replacing the cat, it happened again when I pulled up to a stoplight in the late afternoon sun, in 100F weather, after I had been running errands around town. I shut everything down and pushed my LX to the side of the road, as I often do when this happens, but this time there was a strange sound coming near the gas tank so I removed the fuel cap and it sounded like the fuel was boiling. Even though the engine had been shut down for several minutes, I could see fuel shooting across the inside of the filler neck.
The stumble and stall in hot afternoon weather when at idle (not under load) after having been driving around in the hot weather, has happened to me at least a dozen times in the past 5 years, and it's ONLY ever happened during the summer, ONLY after I've been driving it around in the late afternoon sun (3pm - 6pm), and ONLY after I come to an idle and the engine NOT under load. Last summer, for the first time, it happened on a highway when I was going 60 mph; however, the weather was still near 100F, it was late afternoon, I had just climbed a couple of thousand feet in elevation, and I had just started coasting downhill (ie. engine NOT under load).
I've spoken with a half dozen or more mechanics and read countless forums over the years, but unfortunately, no one has been able to provide a clear diagnosis and solution to the issue. I think @OEMGUY0720 may be on the right track with insulating the fuel lines as I believe the core issue may be the fuel overheating, boiling, etc. I'm not confident it's an issue with the fuel filter, fuel pump, charcoal canister, fuel cap, radiator, water pump, MAF sensor, spark plugs, coils, or any of the other myriad of components suggested by commenters with the best of intentions.
After my 2006 LX stalled last year while coasting on the highway in hot weather (after having been under heavy load), I decided that the hot weather AND the engine NOT being under load may be the key factors (?), so now, whenever I'm idling at a stoplight in the hot afternoon sun during the peak of summer (ie. now), I put my LX in neutral and keep the engine under load (rpms between 1,200 - 1,500). I haven't had it stall yet this summer.
Maybe these experiences provide more clues to the more experienced mechanics on this site to come up with a rock-solid diagnosis and solution?
forum.ih8mud.com
There's also this aspect regarding the timing of reported fuel boiling issues in 100 series:Anything done to reduce fuel heat is a good thing, no doubt!
But keep in mind. Off-the-showroom floor, a new 100 series did not boil fuel, rough idle or stall. Had they, we have countless service history of these boiling fuel, stall and rough idling events.
The one exception I've seen. Is the the 06-07 fuel pump. It is a know issue:
It was a new 06 here in Colo, that from mile 1 to 100K miles. keep going in for a "reported" vapor-lock. Almost always record as, by a statement from customer happening at Eisenhower tunnel. It had gone back into shop, repeatedly for diagnostic including fuel pump/pressure test. Shop foreman, tech and ser mgr. All climb in a drove up I-70 from Denver to Eisenhower, with tech stream hook-up. Still they couldn't find the cause of the issue. This went on for years. Finally after a T-belt job and a report of yet another vapor lock afterwards. Someone in the Shop (Dealership) decided to replace the fuel pump. Issue was finally cleared. Not one report of a stall over next 100K miles. This was never a vapor lock, it was fuel starvation.
Note: Eisenhower, is about about 5,000 ascent up from Denver the mile high city. With a rather long step climb, before entering from either direction. This requires driving in high RPM to climb the pass
Do you wrench?
Based on your driving history statements, you've multiple issue!
Just to be clear: When we say: "engine under load". This is when transmission is in gear (D, 1, 2 3 or 4), and we increase RPM, with foot on the brake. Can also be, referring to accelerating like when passing, getting on HWY, climb a hill/pass, towing, etc..
You've stated different driving condition and one repair:
"Shortly after replacing the cat"
CAT's go bad for a reason. What was the reason? What was done to correct?
Do you sit parked, idling with AC on?
You say "not overheating".
When stopped at a light in D, idling, AC on in summer heat & sun. What is the engine coolant temp (ECT)?
Is ECT increasing, while at light stopped? From and to what temp? Does ECT drop once you start driving, from what to what?
Note: We must read ECT through tech stream, not the dash water temp gauge.
"the engine will occasionally start to stumble and then stall" "when I pulled up to a stoplight in the late afternoon sun, in 100F weather, after I had been running errands around town."
This is somewhat classic of engine running to hot in need of a tune. Even more so, if contaminated/clogged Charcoal Canister (CC). A clogged CC alone will cause this.
"I'm idling at a stoplight in the hot afternoon sun during the peak of summer (ie. now), I put my LX in neutral and keep the engine under load (rpms between 1,200 - 1,500). I haven't had it stall yet this summer."
Shifting to N, increasing RPM, is not under load.
Having to do this, to keep engine running. Is classic of a clogged Charcoal Canister. It could, also be signs of a poorly tuned engine or both.
Additionally we see "misfires" act like this. Misfire is almost always from one or more coils (COP). We test for this in Tech Stream, by watching as we put "engine under load". Foot on brake, AT in D as we raise RPMs slowly. Note: There is a glitch in tech stream. In which misfire disappears under load. There's a video around on this and how to spot the misfire.
" I had just climbed a couple of thousand feet in elevation, and I had just started coasting downhill (ie. engine NOT under load)."
This is classic of a bad fuel pump in the 06-07 100 series. We replace fuel pump and fuel filter, which corrects the issue.
"I'm not confident it's an issue with the fuel filter, fuel pump, charcoal canister, fuel cap, radiator, water pump, MAF sensor, spark plugs, coils, or any of the other myriad of components suggested by commenters with the best of intentions.
You don't give any reference, to why your confident? All and more, need to be in proper working order.
I'll say with some confidence. Your issue is correctable. If you've a heavey (fully built rig), shielding will help. The heavies, have large metal front bumpers retaining more heat than stock and blocking air flow. They also have block air flow, trapping heat with the under body armor. The heat, gets directed along fuel line to gas tank. But even these can be mostly corrected, without shielding. But for the extreme conditions off road in build rigs. In slow, high RPM, long high altitude climbs over rocky passess. That added shield helps for sure. But even those, must well tuned (all system in spec).
In addition to fuel pump and well tuned:
This is 06-07 mod I do, for the S.A.I. system. At some point, all S.A.I. pump filter fail. Toyota believes moisture "may" play a roll in when.
S.A.I. Filter Modification, in VVT engines. To prevent its failure! Alert Alert!
We've a $2.00 part in the S.A.I. (secondary air injection) system of the VVT engine, that is taking-out ~$7,000.00 $15,000 $25,000 (inflation) in parts. WOW! I've a very easy and cheap WORK AROUND. You are going to love this ;) This thread is dedicated to the 4.7L 2UZ-fe VVT engine, in the...forum.ih8mud.com
@2001LC I truly appreciate all your input, experience, and expertise with this issue. It's been a huge thorn in my side for the past several years. If you are saying the 06-07 fuel pump is a known issue then I will add it to the top of my list of parts to replace.Anything done to reduce fuel heat is a good thing, no doubt!
Do you wrench?
Thanks again for the continued insight. I've been trying to read through the entire S.A.I. mod thread this week but it is taking me some time. I'd also classify myself as a very novice mechanic, so I often have to read things multiple times and even then I don't always understand what i'm reading. It's amazing to me that Toyota hasn't provided a proper solution considering how common of an issue this is for many '06-'07 owners.First: If you'd like, we can talk on the phone. Just post your phone and a link to this page in the PM to me. You most likely, have multiple issues. I had bought an 07 with all issue you're having. Just to see what was causing and how to correct. I GF has been diving for ~4 yrs since I corrected all issues, without issues. It is the first one with the VVT S.A.I. mod, my test vehicle.
Yes 06-07 fuel pumps, are a known issue. But not all are bad. Very clear indication is: Hot day typically, full sun in the afternoon. Running engine at high RPM which runs fuel pump at higher speed. This is happens most often here in CO, ascending a pass, As we're in higher RPM for a prolonged period as we climb the pass. But there have been reports out of LV NV, of just passing. We drop RPM back, fuel speed/RPM also drops back, and engine stalls. BK1 & BK2 lean fuel condition. Replace fuel, has corrected this condition every time.
The CAT's both failing are a bad sign. It can be as simple a cause killing them. As prolonged idling. Which the OM (owners manual) warns do not and states 20 minutes. Personal, I don't idle more than 3 minutes. The exception is when servicing, sometime we must.
Unfortunately, the leaning cause of 06-07 both CAT failure. Is in the link I provided, in above post #29 S.A.I. mod. The filter in the S.A.I. pump fails, resulting in a long list os issues.
Fuel and fuel blend is (corn gas) is an issue. But more of and issues is flooding charcoal canister and or engine running hot. With a used vehicle, we've just don't know, if PO overfill gas tank (squeeze fueling pump handle adding more fuel, after auto shut off pump handle), Or did other things that are just the same as overfilling.
So very often I find coolant system low, rad cap or reservoir not working properly and most of all radiator fins clogged.
Your dash WATER TEMP (AKA engine coolant temp, aka ECT) gauge is a poor indicator of actual engine coolant temp. Since your having issues. I suggest you get a OBD device to watch ECT, fuel trims, CAT temp, AT fluid temps, ect. I use OBDmx, since its open software allows you choices. But there are many device let you watch tech stream and log data on your smartphone.
Here just a random picture of "DashBoard" I set up on my iphone, to watch on 06-07. They (06-07) gives use CAT temps and A/T 1 & A/T 2 fluid temps.
You're correct! We can't just replace CATs. We must correct root cause(s) of failure.@2001LC I finally got through reading several of your other threads going back several years, the Snowy resto, etc. Only took me a year to get to it.
Based on your descriptions, I'm about 98% certain the SAI filter under the manifold on my '06, is probably disintegrated and gone. I'll need to do that mod. I replaced both CATs maybe 2 or 3 years ago after the CEL gave me the 0430/0420 error codes, even though I was adamant with every mechanic that replacing the CATs wasn't fixing the underlying problem. Nonetheless, I needed to get it done so I could pass smog and renew registration since it is my DD.
Well, I had no CEL for the first year or so after replacing the CATs, and then after the first couple of engine stumble-and-stalls the next hot Vegas summer, the CEL came back on, and it has been coming on and off ever since. No surprise to me, but still frustrating as he**. I've been able to get it to pass smog the past 2 years by going on days when the CEL was off, but over the past 6 - 9 months, the CEL has been coming on and staying on more frequently and for longer periods. I doubt I'll be able to pass smog again next year without replacing the CATs again.
I've never seen the need, as no replacement has even had issues.I also need to replace the fuel pump. As @j3cub asked above, do you know if it is possible to install the larger '05 or earlier fuel pump in the VVT-i engines?? If we replace the same smaller '06-'07 OEM fuel pump, how long can we expect it to last before its starts to fail again in hot afternoon weather when coming from high rpms to low?
I've replace many fuel pumps, 98-07. There's a ton of thread on how to in iH8mud. I was using the $100 Denso fuel pump in the VVT (06-07). But they're no longer available (Denso no longer manufactures. I do see some for sale online (could be old stock or boot leg)). Other alternative fuel pumps are noted in ih8mud. I just use OEM these days. Which OEM comes with cage & socket. I also replace the rubber grommet at bottom of fuel pump and the short hose at top of fuel pump.Lastly, can you post a link to a thread showing the parts needed to replace the VVT-i fuel pump and how to do it? Do we need to replace the entire pump or just certain components of the pump? I know there are youtube videos out there and probably some other threads explaining how to do it, but I trust your first-hand experience. Thanks!!
