238K for me, I noticed small drops in the overflow tank and having done all the hoses knew I had a problem. Caught early as the truck was running great, well worth it to have that in the rear view mirror.
I currently plan to have the TB off, the valve cover off and the upper intake off. My guess is that is halfway or so there.....
That’s interesting to hear.^^^This^^^
What the dealers in your area have told you is not correct, they can order the short block, key is first using the correct part number IME.
Part of the problem may be that you're in Florida which means all the Toyota dealers are part of SET (Southeast Toyota) which uses it's own parts ordering system. Those dealers (in SET) are technically not part of Toyota North America and don't use the same system as Toyota USA for ordering or tracking parts (the parts gurus could explain it better)
Toyota Short Block Assembly #11400-66041 | Autoparts.toyota.com
Genuine Toyota Short Block Assembly for smooth power delivery, balanced performance, and exact-fit lower engine support.autoparts.toyotaofdecatur.com
I’ll PM you, sounds like an option I need to explore.@Damcowboy if you end up needing a long block i have a freshly rebuilt one sitting in the shop. Pm me if interested. And everyone is right you can definitely get a new short block from Toyota you will just have to transfer over all your old alignment pins and dowels and everything else easily done on a engine stand with the FSM.
138kSadly I see this scenario playing out continually. The Legendary 80 series is bulletproof up until about 220,000 260,000 miles then it blows the Head Gasket (anyone who says otherwise is BS or extremely lucky. One could argue that replacing the HG isn’t a major repair, you can slap a new Head gasket in and be back on the road. Unfortunately there isn’t a lot of engine options for the 80 and having to pay labor on repairs will cripple most common folks, Unfortunately you can’t go down to the local junk yard get a used engine to swap in like you can a Ford.
I didn’t get to see how many miles were on your 80 when it died on you.
Yes, exactly my reaction …
Unfortunately this can happen to anyone, and on any vehicle really. I stopped using Wix filters in all my vehicles after reading multiple reports here of oil starvation linked to their filters and actual payouts from the manufacturer showing that the loss was definitely attributed to their poor design or manufacturing process. Not everyone knows though and it's obviously a problem Wix isn't fixing so there will be more. Who knows what other filters and applications are affected. I've found the Toyota OEM consumables to be inexpensive as well as high quality, of course that's of no consolation at this point for you.Yes, exactly my reaction …
138k
Is there any vendor out there that builds plug and play engine harnesses for a 97 LC?
Use a good camera and as you take parts off, bag and label them. Take a photo of the bag and where the parts came off; point if you have to. Also, place the parts in boxes dedicated to the area the parts were removed. It may seem like you are going overboard but, it will save you time, money, and grief. Also watch for your bolts on the assemblies. Some will be longer than others. Use a piece of cardboard with the shape of the part that is being removed on it. Stick the bolts in the order/place they came from. The oil pans are a great example of this. Trans too.Its out. I hope i can remember how to put it back together.
I suspect i have already NOT taken enough pictures
