I think the issue with water cooling the turbo on a 1HZ is that the engine coolant actually heats up more with the added job it is expected to do in cooling the turbo... and IIRC the HDJ has a larger radiator which I assume is because it is running a water cooled turbo. I would suspect that like a lot of things Toyo perhaps went for a belt and braces type approach in water coollng the HDJ. Some aftermarket turbo kits that I looked at do water cooloing, some don't. Certainly with my HZJ with the CT26 turbo I have found in very high ambient temps that the cooling system is certainly taking strain! It is not that it overheats, but put it like this there is another engine temp gauge and an EGT gauge on my rig for a reason... A friend who is a CAT Engineer has suggested that if I do fit my ebay Celica A/W aftercooler that I could circulate the added cooling circuit with my 100 liter underbody tank - and also add the turbo into this second cooling system. I will probably not go down this route as the vehicle may end up in colder climes and I don't really want to shower with glycol But it would be interesting to see the effects and get a warm shower at the end of the day!
