91 3FE. Replaced the water pump, thermostat, many after market hoses that were on there with OEM, and replaced the radiator with a 3 core aluminum. I also flushed out all the lines and the heater core.
Are there any recommended procedures on refilling the coolant, like leaving the cap off to get the air out? Turn on heater? Also, is the Toyota coolant really that much better than Prestone or similar standard coolant? Don't care to spend double the money if the standard stuff will work fine.
Thanks for the advice.
