destins 1964 fj40 FST restore thread (2 Viewers)
I'm skeptical on 2K for all brand new parts. The F120 I did cost $1800 in machine work, but that included sleeving one of the cylinders. then it was another $1200 in parts which included new Toyota pistons and all the other internals/oil pump/water pump, etc.
2K is a great price. With parts and labour I have closer to 4K in mine. Traditionaly these simple inline 6's are not cheap to rebuild. Thus the reason many opt for a V8 conversion. Many times it is a cheaper route. I love my 6. It has more than enough power and torque for me. If you want to hear a rebuilt 6 let me know. Mine has 250 miles on the build. No muffler yet though. Anyway....my .02.
Thanks guys
Dman that motor sounds nice :D
OK so quoted a great price to pull and pop the motor in :)
Thanks Shane!
Walked to the engine rebuilders today ( yeah is that not great? They are 9 blocks form me :) )
So with a rebuild you get 3 year unlimited mile warentee :)
Sounds pretty good.
All parts he said he could get in a matter of a few days if he did not already have them, we will see.
Hopefully drop the motor off before the end of the week.
So things i should get...
1) new oil pump? ( what is the part number btw )
2) timing gears?
Found this OEM dist that is said to fit my 1964...
says 2f on the label though... thoughts?
2) timing gears?
That's the distributor I have.
I got a new timing gear to go on my new cam. I suppose you'll have to see how yours looks.
You can check your oil pump and see if it needs refreshing. If you get a new one it won't fit your oil pan exactly, I think. You'll have to cut baffles. I just checked the gear lash on mine (was ok) and replaced the grommet and kept it original.
basically they used non usa dist in the 2f's. so your good to go.
Right on :D
Thanks!
Cheers! Ill drink to that!
Im in the middle of a cooling system rehab on my 69. It decided to start leaking anywhere it could. Heater cores been rodded, new rad, all new hoses, waterpump, thermo, etc. Hoping I can drive it soon!!!
Nice man :D
Yeah after I replaced my thermo housing and thermo stat with new hoses etc, my temp gauge never really crept over the warm zone :D
However my engine did take a s*** hehe :D
Hopefully there is nothing left to go wrong hehe :D
One thing I learned and that you might want to know. I and my PO had trouble with fresh freeze plugs leaking. I tried all sorts of things but ended up using 3M's the Right Stuff to hold them in without leaks. There may be other stuff that's even better, but it was a big headache pulling and replacing.
It turns out, if you check the 64 engine manual you will see that the pressure rating for the radiator cap is 4 lbs, rather than the 14 lbs that Toyota sells. I think that that at least contributed to my blowing one of the freeze plugs one morning last November. I found one at NAPA rated for 4 lbs that fits, and it seems to be OK so far. I am not the only one who has had this issue with F135. The F145 is rated at 7 lbs, and that is available as well.
