if i put on a header and a weber, do i need to recurve the dizzy as well. And can i remove the millions of miles of vaccume lines? Also is it fairly simple to gut my air pump.
85 fj60 2f
Doesn't it stink of gas fumes with the charcol can disabled? Seriously, just because you hate vacuum hoses doesn't mean you need to pull all of them - some actually make the engine run better.
az does require smog, but my buddy is a master at tuning carbs to pass. We passed an alfa romeo with dual side draft webers and straight pipes, and that was a little hot rod. If i have any trouble i'll run ethenol AKA rubbing alchcohol, safeway sales the 99.9% stuff. I did that last year and got nearly all zero emissions. or E85 might be wiser to try first nicer to the valve train
