Desmog components (8 Viewers)
It will look like this beta test, but probably not brass. AL should work fine and machine almost as easily.
Toyota sent a tracking #, so the long delayed EGR gaskets may be here in a couple days. If gaskets are in this box, then several orders that were held up will go out posthaste.
If no gaskets, I will contact individuals to see what they want to do: refund, wait, something else...
Thanks for your patience, good citizens of 'Mud!
So I started removing the smog pump today, thanks JimC for the pulley. All seems good but then I started looking around at other smog equipment and saw the PO had switched lines on the distributor vacuum lines. I went to reverse them and the vacuum line housing disintegrated with rust. I guess I'll pull that piece of smog equipment as well but is that something I can do without if the rest is smogged?
EGR gaskets are here, so several orders will go out Monday.
NOVA, if the vac advance can on the dissy is rusted to death, then pop the cap and make sure the centrifugal advance mechanism is not also rusty. If centrifugal is OK, then it can be run indefinitely with the vac diaphragm disconnected and plugged. It would run better with a functioning vac advance, but running without it won't cause any damage.
Jim,
So my gasket is on the way too?
Yes. PayPal should have sent a shipping email this AM. PriorityMail so it should be there Wednesday. Thanks!
Hi Jim,
Sent paypal payment for a Desmog Kit (EGR, Gasket, Caps & Plugs for 77' 2f). Looking forward to receiving the gear!
Mason, got the PP, Thanks.
Was OOT for Columbus day weekend, back at it in the shop now. All current desmog orders shipped.
LMK if anybody hasn't received the stuff or at least a tracking number.
Me Jim. i desmogged my fj60, it's running rich. I think I need to take advantage of your services. I need to send you my carb and my distributor?
You should of recieved the carb by now. Do I get notified about this?
Yes, UPS is supposed to send you a note that says "03:45PM 10/14/2016 package delivered to man at garage", or something to that effect.
There is a box here with your name on it, that's all I know at this point.
Hi Jim - how do I go about ordering a desmog pulley? Been running a dummy air pump, and I'm ready to move on :)
Thanks for your interest, 55.
Check out the first 2 posts in this long thread for price & descriptions. Figure out what you want to get, add up the prices, add $6 for PriorityMail, and PP that to my mud ID at gmail dott com . A little note w/ the PP mentioning which parts you're getting is helpful. That's all there is to it.
