Delta VS
Supporting Vendor
Howdy folks!
Quick intro for those of you not familiar with Delta Vehicle Systems. We have been making/developing products for 80 Series for a little bit now and are getting ready to start some 100 Series offerings in the very near future.
Our Panhard Lift Bracket has been quite a hit with the 80 Series folks (you can read all about it and why it's helpful here: Delta Vehicle Systems Panhard Lift Bracket, 3" & 5") and we've had plenty of requests for something similar from 100 Series owners. We have prototyped a couple different versions, both of which can be seen here:
With both of these on the vehicle, have a few questions for y'all:
1. Situation:
Anyway, as you may have noticed, one of the advantages of the drop bracket is it can be built so the drop distance for various lifts can be accommodated by one bracket, unlike the 80 Series (we have to make 2 different brackets for that application). That way if you go bigger on your lift, you simply drop down a notch on the bracket instead of buying a new bracket.
If you have any questions, feel free to ask!
Thanks,
Dave
1. Situation:
The panhard LIFT bracket (80 series style, mounted to axle/driver side) would REQUIRE bump stop extensions, leading directly to the loss of up-travel. This is because the 100 Series does NOT have the same amount of clearance between the panhard mount point and crossmember as an 80 Series. The one in above pic has about 2.5" of lift for the panhard since that seems pretty typical for a 100 from what we have been able to find (certainly welcome input from anybody on that). So, 2-2.5" bump stop extensions would be required to avoid smashing the bracket into the crossmember above (right behind the drive rear spring basically).
Question A: Is that an acceptable trade off for you? In our mind it is not an acceptable trade off (improved handling in exchange for loss of suspension travel)
2. Situation:The panhard DROP bracket (mount to chassis/passenger side) in it's current form has the slightest bit of interference with some of the stock stuff. BUT, this rig has adjustable lower control arms that may have lengthened the wheelbase (the wheel absolutely looks offset to the rear of the vehicle based on the wheel well).
Question B: would a handful of you 100 Series owners be willing to measure wheelbase from center to center of your (stock lower link) 100s? Pretty please...
Thanks,
Dave
