I appreciate the advice and postings on this site. They have helped me tremendously. I thought I would share what I used for my defrost hoses on my '74 FJ40.
I was missing the entire hose/elbow/coupler on the left hand side (driver side) . Had the elbow hose and coupler on the right hand side but the coupler was ripped badly and not functional. The PO had used some aluminum duct tape around the upper portion of the hose and coupler but it was failing. The elbow was a little dry rotted but still functional. After cleaning the hose it was actually still in great shape.
After seeing some of the ideas here, I started trying to figure out if I had anything I could use. I remembered I had saved the dust boots off of some Bilstein 5125 shocks I had bought a year or so ago. I tend to save stuff like that thinking I might need it one day.
The rubber boots from the shocks actually worked really well. Here are some pictures:
Above is the test fit of about a 2.5 inch length of the boot on the metal cylinder under the dash passenger side. The rubber stretches enough to provide a snug fit.
Above is a little bit blurry picture of the factory hose inserted into the boot being used as the coupler to the metal cylinder under the dash. This pic was taken through the ashtray opening.
Above is a picture of the passenger side factory elbow connecting the hose to the heater. My "74 has the oblong opening at the heater.
Above is three sections of the the shock boots fitted together for the driver side.
Above is the shock boot derived defrost hose inserted into the heater opening. The rubber was flexible enough to conform pretty well to the oblong opening.
This greatly improved the effectiveness of the heater by the way. Apparently a lot of the heated air was being blown out the open driver side hole before. Now that the hose is there, more air comes out the louvered portion directed toward the driver and passenger..
Anyway, I thought this might benefit someone else looking for a cheap alternative for the defrost hoses or couplers.
