1: No. If you use the ratio between the distance from the front arm bolt and to sensor bracket compared to the length of the whole arm, you get the ratio of slot movement to axle movement. I.e. the truck will move more than the distance you move the arm in the slot.1. Is this a 1:1 correspondence, i.e. moving 1/4 inch down lowers the rear height 1/4 inch?
2. Is it odd that I had zero issue getting the springs in in my 06 LX without doing anything other than removing the lower shock bolt? I didn't even unscrew the brake line from the attachment. I had planned to, but proceeded without by watching everything closely as I very slowly lowered the axle, nothing (brake line, breather line, height sensor) seemed even close to reaching a stress point.
2: No. Pretty easy and standard. But when the shocks are off, it is possible to lower the axle more than those lines allow for, therefore the warning.
