They fit snug as a bug lots of off road trips without a strap on them. You do have to trim the fins a little on the side of the battery but it is super easy and takes only a minute. The rear part of the OEM tray has a slight triangle bulge. You run into a similar problem with the Yellow Top but the DHPM can be adapted much better for a perfect fit. The DHPM also has a nice carry handle to help with the install and removal. I have lots of electrics running to my batteries, 5000w FyrLyts, 50qt ARB fridge, Full Kicker stereo system with 12" Sub, PUMA OBA, TJM 12,000 winch, etc.
Its the perfect setup for me. I like to play music while camping, or hanging out at the river or lake. My system can play all night without any worry of the cruiser not starting in the morning. My fridge also runs comfortably at 32F all at the same time for days on end. I also leave my phone charging and let people fill up their air matresses without starting the cruiser.
I was a die hard Optima believer when my two red tops powered my car with a failed alternator from El Golfo Mexico to Yuma at night with high beams on. Since trying the DHPM I am very confident they are a superior battery and the specs show this. I also ran all of the same stuff on one DHPM 31M before I purchased my dual battery setup and it ran great. Before that I had a regular DHP OEM spec and it was fine until the first discharge. It made my fridge act weird and was a disappointment. I say go big (31M) or you might not make it home.
