Dead engine with only 135K miles....now what?
If you want to go Diesel route and have 40K to spare check out these dudes. Tundra Diesel | Diesel Toys® |TOYOTA DIESEL CONVERSIONS
Link straight to the 200 Series page: 200 Series Diesel
HTH
P.S. Two of their "Policies" one should bear in mind:
Off Road Policy
Diesel Toys ® provides diesel conversion services for “OFF ROAD USE ONLY”. Diesel Toys ® does NOT imply legality or any other use of conversion services rendered and cannot be held responsible for any fees, duties, or losses associated with conversion services or for any other reason.
Diesel Toys LLC Warranty
Our conversion services are rendered using “used components” and as such, offer no component warranty of any kind. Diesel Toys ® will handle any quality control and/or installation issues on an individual basis. Diesel Toys ® is hereby NOT bound by any legal obligation warranty any item on the vehicle. Diesel Toys ® handles any issues at our sole discretion and no written warranty is expressed or implied.
Not to mention: having an engine and major systems that you can’t readily get parts for in the US. I have a contact in Japan that can get most things here in a few days but trust me.. you’ll pay. Though I guess if you have 40k to blow on an engine that is demonstrably less capable than ours other than fuel tank range, you won’t mind paying shipping for parts. And they aren’t even that reliable!
Plus what happens if the builder goes under and you need support?
Like the idea of dropping in a tundra motor. Imagine it’s somewhat plug and play but still a decent attention to detail job? What type of labor cost does something like this usually run?
Having done more than a few engine swaps, several with motors that didn't belong in the vehicle to begin with, I'd say you need good detail orientation, patience, and a willingness to grind through troubleshooting. The mechanical bits are generally easy. Some swaps are easy, plug and play, but then you'll get some small things that'll have you chasing your tail. I had one used engine in pristine condition that had a bad crank position sensor that stumped me for days, and another where the immobilizer stumped me until I pored over wiring diagrams from the donor and recipient for at least forty hours.
It has been done with the details posted in this section. Will require some searching. From memory it was 97% drop in, with a couple little sensors or brackets being different.
It is easiest of you have donor and recipient engines side by side. Ziplock baggies and a sharpie, plus tons of pictures helps a lot!!
