I did a search on the forum and found a few semi relevant threads but not exactly the same as the issue I am having.
It’s a 97 with 180,000, we have put about half those miles on and it’s been a great rig.
It will start right up, idle high for warm up and then when it kicks down it will stumble and sometimes catch and idle fine for 30 seconds and then stumble again and die eventually.
While driving at mid throttle it will sputter bad, but the engine rpms remain steady. Give it full throttle and it kicks in. At full throttle it has no problems.
There was some corrosion on the battery terminals, cleaned that up and it solved the problem for a couple of days and then went back to doing the same thing.
It seems like an electrical problem. Plugs, wires, cap, rotor are not that old. Cold weather could be a factor as it didn’t do it until it got cold. Intake air temp sensor?
TPS?
Just replaced the fuel filter, didn’t help.
Open for suggestions.
It’s been a while since I posted here and couldn’t remember my log in so new account.
TPS?
