gbentink said:...I dont see too many 13BT CT26's, they are quite rare and if any turbo was not the right spec on a Toyota Diesel it is the CT26 on the 13BT.
I have a 13bt with the ct26. What would you recommend as an upgrade?
gbentink said:You wont be able to use the dump pipe, Im certain of that. You can buy CT26 exhaust flanges of eBay, best to use that.
I dont see too many 13BT CT26's, they are quite rare and if any turbo was not the right spec on a Toyota Diesel it is the CT26 on the 13BT. Of course, it is much better on the 1HDT. On the exhaust housing it probably has 58010 cast into to turbine flange where it bolts to the exh manifold; that is the same as the 11HDT. On the compressor side it will have an inducer between 41.5 and 43mm. 1HDT are 43mm. I *think* the 13BT is 41.5mm like the early (Gen1) 3SGTE motors.
Given you are obviously on a budget and you wont push it past 12psi on a 1HDT (assumption and advice all in one), you wont notice the difference.
You will need to use your 1HDT wastegate actuator in order to actually get the wastegate to worik - after you rotate the 13BT housing, it wont reach the wastegate lever.
Hope that helps. Cheers
If you still have the CT26 that came off the 1HDT engine initially, and it is in good working order, you can simply use the exhaust housing from the 13BT version - should be identical in every way. Just check the number on the exhaust flange. Should be 58010. If that is the case, happy days, low cost for you and right back on the road.
Adam B said:Just a note here about exhaust housings, taken from the parts I used to make the hybrid I ran a couple of years ago. I bought a used CT26 from a 7M-GTE, split it, had it rebuilt with a 360 degree thrust bearing, then popped the exhaust housing off my stock 1HD-T turbo and put it on the rebuilt 7M unit.
1HD-T = 58020
7M-GTE = 42010
There is a HUGE difference in size.
I need to take pics of my supra housing .. but mine isn't that big compared to my 1HD-T housing ( turbine side ) need to check numbers tho ..
There is more than one ct26 variant for Supras, the 7MGTE version had the largest compressor wheel and housing.
The turbo that i will be using has the 42010 that came off from a 13bt, does this mean that 13bt has a bigger turbo compared to 1hdt with 58010 exhaust housing?
