Builds Cruzilla BJ41 from Russia (1 Viewer)
Good plan :)
I need help, advice or instruction. I understand the work and airshox device, but I can not understand how can I reduce body roll. On the Internet a lot of benefits for setting up, but I'm very hard to understand without knowing the language. When you turn on a slope, my car was bent to one side. To solve this problem, I plan to make the custom sway bar, but also want to set up airshox. In the back, I added on the 10ml oil , and they have become more rigid in compression, but the problem persists. What should I do?
Help the simple and clear advice
Air shocks are a balance of oil level and pressure. However, getting a sway bar is pretty much mandatory.
What are your oil levels and pressures right now?
Front 16" 2.5 - stock oil level ( 655 cc ) , 16 kg/cm
Rear 14" 2.5 - stock oil level + 10cc ( 585+10 cc ) , 14 kg/cm
Simplicity is paramount for these vehicles and as such you have achieved simplicity coupled with the diesel engine and unique design! And I love the color and matching wheels too! Great work!
Turbo Time!!!!
Unleash the beast
20 psi=happiness
Turbo Time!!!!
I already bought toyota sc-14 superchsrger, for installation. Most of my motor in very short supply of the automatic transmission. And then I fear, may be swap 5VZ-FE + auto trans :) .. But the meaning of this idea, I do not understand to the end, yesterday installed the exhaust system, and realized how beautiful the sound of a diesel engine .. Still would go well ...
is that CO2 tank viable on its side? pr do you plan on mounting it vertically for use. ive found that having it mounted and just using a longer hose works better for me.
I plan to install it vertically in the same place, just need to buy a special attachment. The horizontal gear strongly freezes because the gas is vaporized therein.
Eggzachery :)
Did you get your body roll problem fixed? In Avstralinksi, the Nissan Patrol came from the factory with a sway bar that can be locked [road use] and unlocked [for flex].
there are simple solutions to the jeep wrangler. But I'm not used to solve the problem simply)) I made a torsion bar, sway bar arms made and I hope as soon as possible to realize this idea. Body roll I partially removed фшк shox setting. Later I will make photo
