It was level before that so the way i tbink it should be level afterwards.. unless there was a problem. Seems like bolts did not fix itNo. Shouldn't have. Not unless they did something wrong!
Took mine to dealer for front strut spacers and they had a hard time getting it level. After keeping it for extra day i got it back and difference in the rear is 30mm and 23mm in the front... all is higher on the right.
When you do spacers any chace of getting air in?
Can you post a picture of the KDSS valve and where the hex key goes? I have lean on the DS bad (no lift)
I had similar problem. Ended up using 3 points to lift running around measuring with tape. 2 in the rear under the axle and one up front. Front one was lifting up the frame - uncompressing the shock so put it on the lower side...The front of mine is about an inch off. The front is harder to lift than the rear. Putting the jack under the control arm raises the whole vehicle so the wheel dots not actually compress the spring at all. Anyone else deal with this?
