crushers
post ho
cross_country said:I am driving from ottawa to calgary, then vancouver in a couple weeks. The last time I was in calgary I noticed a bit of black smoke. I thought I would get my compression and injectors tested to see what the problem was since the cruiser (bj60) shouldn't be smoking at 1100m.
I have since decided to forget about the compression since I can't do anything about it and would rather not know if it is bad. At idle when I put my hand in front of the blowby tube, the exhaust coming out has about as much pressure as I can blow with my mouth.
I was still planning on having the injectors tested & rebuilt if need be but this thread has turned me off a little.
I was able to get from Regina to Calgary on one tank before if that gives anybody an idea of the mileage I get. I think thats about 750km on an 96L tank which i probably ran down to about 80L or so.
don't be an ostrich with your head in the sand, get the compression tested. better to know the bad news than get half way here and run into problems. it can get expensive in backwater Canada to fix a diesel....
do you have an altitude compensator on your pump? if not then you can get black smoke here in Calgary. my HZJ75 ran clean in Pismo at see level but here in Calgary it puts out some very heavy black smoke under throttle... i am not concerned about it at all but the guy behind me might wish i would...
cheers
