Cracked Radiator
Just happened to my 2013 LX570 at 120k. Didn't even notice till I opened the hood to connect my pump to the battery to air up tires. I have no idea when it split, but the reserve coolant reservoir was empty. I filled it with water and drove conservatively the 40 miles home—all the while closely watching the temp gauge. By the time I got home one hour later the reserve tank was only down about an inch from full. No overheating. Much will depend how bad your split is.
My advice is to look into possible reasons the radiator broke. Overheating, old age, poor build quality, bad head gasket, etc...
As cheap insurance, go ahead and have your radiator cap replaced as well in case there was a pressure related problem.
Don’t forget off highway use. Corrugated roads will wreck a radiator due to the vibration.
Once the radiator cracks and the coolant explodes, is it still safe to drive the 200 to get it repaired? Or should one get it towed?
Really depends. It could be fine. It could be a disaster. Watch your levels, temp gauge, and especially if it sounds like air is getting in. They run higher pressures today.
back before 1987, when i bought my first new LC, I drove a Series II Land Rover 109 station wagon. It was 20 years old when i got it and the brass radiator was always cracked. Made a mess similar to the attached photos but, as long as i kept it topped up, never gave me any real trouble. I drove that old rig down to Brazil and back one summer on the broken radiator.
When mine finally went, it was at 140k, on New Years Eve. Discovered it at 2 in the morning when giving a car a jumpstart. Great way to start the year. At any rate, wasn’t going to get the repairs done for a few days and needed the truck. I cleaned it up, topped the radiator and reserve tank, and rolled up an old bath towel and laid it across the top of the radiator, wedged in by the closed hood. This was mainly to keep additional coolant from spraying all over the place. Due to the holiday I ended up driving it this way for a week. Kept an eye on coolant levels, and watched my temp gauge constantly. Temps never went above normal when the engine was warm. This was just in town driving, and definitely low load. For peace of mind I’d get it fixed ASAP, but if you’re super careful you could buy a day or two. Watch that temp gauge 👍
Yep, watch the gauge. As long as you aren’t doing any high-load driving like towing or sustained high speed freeway you are likely just fine to drive it a bit.
Agreed. I'm pretty sure it happened that day while driving on rough forest service roads.
My radiator just sprang a leak. 2011 LX570 with 161,000 miles. Dealer quoted $1,200. Bummer.
Are there any viable aftermarket solutions? Some of the all aluminum radiators look like top notch quality. I think I have heard of people getting custom radiators made for less than $1200.
Yikes. Theres nothing out of the ordinary involved in the 200 series radiator replacement. I spent less then that when i had an independent toyota shop do my radiator, water pump, thermostat, belt and pullies. I supplied the parts and they charged around 3 hours of labor.
And what about install? The OE rad itself is only about 400 of that bill.
Aftermarket has been discussed at length. OE got redesigned and seems to have addressed the issue, and will in all likelihood be better long term than almost any all aluminum unit. Available online for $280ish
Mine looked the same way yesterday, 2013 LX570, so much for build quality huh, Seems Toyota's move to plastic-aluminum radiators was a manufacturing and engineering compromise that prioritized initial cost savings and weight reduction to gain mileage for the EPA, despite the known trade-off in long-term durability compared to older all-metal (copper/brass) designs.
Interesting that toyota would stick a plastic tanked radiator into the ultra utilitarian 70-series over which the EPA has zero influence then.
Yeah that has nothing to do with plastic radiators and everything to do with a flawed part specific to the 200 series. Why Toyota/Lexus took so long to address it is the problem.
