To the wise and experienced members of MUD, I am starting my first engine rebuild and hope you can shed some light on some of the finer details. Thanks in advance!
Turbo'd 1981 Bj60, 3B. 495,000kms, unknown history but (I think) non oem head gasket so has seen some work in the past.
Engine was running fine, compression was decent, 390-425 psi, but a small bubbling leak at head gasket above the water pump got me investigating and maybe the OCD took over a bit. I took it all apart!
Little bit of cleaning (scotch brite and oven cleaner)... got me here.
The cam shaft and lifters are in pretty rough shape, with only one lobe measuring at limit, the rest undersize.
So... I found a seized bottom end for cheap (<300,000kms) and robbed the Cam shaft and lifters, which are in much better shape. Not perfect either, but way better!
I was then concerned that I probably lost some abrasive particles on the top ring, so might as well keep going.
The plan is to rebuild this current motor with new (to me) camshaft and timing gear set. I hope to go inexpensive, not cheap on this.
Then while im driving around on this minor rebuild, my new to me seized bottom end can slowly be properly rebuilt. New sleeves, pistons, bearings etc. Probably new camshaft and lifters too. Eventually get another head and rebuild it so all ready to drop in one day. This is a good winter project, but now I want to be
and too much $$$ to do the whole she bang at the moment.
I enjoy these kinds of projects, and partly why I bought the truck in the first place.
So Questions;
If I read the FSM correctly, the cylinders are allowed 0.012" wear to the liner to be within the 'wear limit'
Yet further on, piston oil clearances are tight (0.0008 between max/min)! and even differences in piston/liner 'mark' sizes are tiny (0.0004" difference between marks) compared to the 0.012" wear. Not sure what to make of these numbers. Why so tight tolerances if 12 thou wear is allowed?
So this is what I am measuring on my rig. I am hoping to give the cylinders a kiss with a flex-hone (a couple tenths of a thou), new rings, and reinstall. I will measure cam/crank bearings... was planning to replace, but so far everything measures/looks near new.
I need some plastigage to measure oil clearances, or can I just pry on the shafts with a dial indicator to measure??
Cylinder measurements are in thrust direction (wider of two numbers) at top of cylinder. MAx 0.002" taper and out of round. My bore #'s have some room for error as I am using (cheap Chinese set) telescoping gauges, and then measuring with a micrometer. I would say +/- 0.0005"
CYL# | MARK | Cyl MEASURE | Piston MEASURE |Oil Clearance
____________________________________________________
1 | 2 | 4.0172 | 4.0114 | .0058
2 | 3 | 4.0168 | 4.0119 | .0049
3 | 1 | 4.0159 | 4.0119 | .0040
4 | 2 | 4.0167 | 4.0111 | .0056
I think this looks healthy and a good candidate for a quick hone and re ring. But I have never taken an engine apart before, not sure what is normal or not.
What say ye wise Mud members?
If this is feasible? would I replace standard rings matched to the piston/cyl mark#? Oversize and file to fit?
Or is this a plan for disaster?
Cheers!
and too much $$$ to do the whole she bang at the moment.I enjoy these kinds of projects, and partly why I bought the truck in the first place.
So Questions;
Cheers!
