Costa Fabrications intro and offerings. (1 Viewer)
Here is the standard side plates that will go out if no logo is added
Rich
Stainless will warp less and if you elevate it a couple inches it will be legal in national parks like Canyonlands.
Park service doesn't allow the fire to contact the ground and leave burn marks. I was using a Volcano
grill at the Doll House in Canyonlands. Although the fire doesn't technically touch ground a ranger
asked me to elevate it with stones. I think it's a judgement call as to how close is too close to the ground
Here's a shot of the side plate with CB Adventure Supply's logo cut in. Their a brand new overland supply shop in Texas. He's a mud member as well and a great guy. They'll offer product and service. I'm excited for him. He bought the very first one of my 80 series front bumpers. Look for them at the Overland Expo East. He is also a Turtle Back dealer.
And here is the latest version. With cutouts to hold a standard grill top on the vertical sides and rounded notches to lean a poker with a hot dog, marshmallows or whatever else you wanna roast on a stick. And the bottom is no longer straight across. There are raised cuts for clearance to accommodate for uneven ground surfaces. Again the handles and finger holes are oversized if you are wearing gloves in the winter. These are 299.00 plus shipping. 65lbs , 1/4" steel construction.
Very cool. Perhaps one of those heavy canvas bags to hold that when not in use? Just a thought. Love the bumpers as well, what is your current turn around time?
And here she is loaded up. Just need to mount the plate and hook up the lights. Im pretty happy with how it all came together. It looks killer! Im gonna do a color change later. she'll be put to good use this weekends at the yankee toys fall gathering. What do you guys think?
a shot from this weekend.. wish I got more pics...I didn't get my sliders on so I took it easy. The 80 made short work of all the obstacles encountered and the air actuator conversion on the rear locker worked awesome! I'm really happy with the mod. i'll look into the front next. All in all a great weekend with great people. The Guys from Iron Pig actually won the fire pit I made for the raffle. That 80 in front of me on the trail came all the way from Atlanta with a sweet turtleback trailer. I'll definitely go back next year...
Costa Fabrications is now a dealer for Snowmaster Fridge/Freezers. check out the link for details. If your in the market definitely check these out! Build Quality, features and warranty wise you'd be hard pressed to find a better fridge... Below are just a few models. check out there site for more.
link to site SnoMasterUSA
link to features Features
Rich
Also for those that don't know I'm a dealer for Factor55 and ZeroDark lighting as well.
The Expedition series was designed for those who don’t have access to 120 volt for long periods of time and so the battery amperage draw is paramount. The unit’s insulation is thicker than our competitor's at 77mm/3 inches, for better maintenance of temperature. available in 75L, 95L single door or 66L, 85L combo fridge freezers.
Dual AC/DC 12/24 DC 110/220 AC fridge or freezer with Stainless steel cabinet, hinges, locks and handles and Lid open Alarm.
3 Internal baskets included, Temp variance -7ºF to 50ºF, Digital thermostat, LED Light /Lid alarm. Travel bag and remote included.
Size: 32.48 x 20.08 x 21.07" 825 W x 470 D x 535 H mm
Capacity: 66 Liter (30/36 Split)
Weight 70.5 Lbs
70mm Polyurethane Insulation
Stainless Steel Cabinet, Hinges, Latches, Handles
Solar wireless temperature controller
Battery Monitor
Snomaster 66 Watt Compressor
5 Amps on High Speed, 2.5 Amps on Low Speed at 12v DC
Voltage Cut Out can be set between 10.0v & 11.5v DC
AC-DC
$1249.95
With a stainless steel outer shell, the CLASSIC SERIES is designed for general off road use, giving to its larger size. It’s tried and tested by casual campers and 4×4 enthusiasts who are not heading into extreme conditions. Just what you need in high quality at an affordable cost. Also available in 40L, 42L, 75L, 95L single door or 66L, 85L combo fridge freezers.
Size: 29.14 x 19.50 x 20.80" 715 W x 450 D x 525 H mm
Capacity: 56 Liter (32/24 Split)
Weight 59.5 Lbs
60mm Polyurethane Insulation
Battery Monitor
AC-DC
$1149.95
The Stainless Steel traveller Range was designed for the individuals that are looking for a smaller unit that can be used for shorter Trips with a less fair to keep cool. The unit is more compact and can fit into the trunk or backseat. Also ideal for a second Fridge/Freezer for gatherings or family outings. and the Stainless finish is easy to clean and scratch resistant.
Size: 14.33 x 26.78 x 20.28" 364 x 680 x 515mm
Capacity: 42 Liter
Weight: 52.9 Lbs
Single Compartment AC-DC 12/24 DC 110/220 AC
Fridge or Freezer
Lid Open Alarm
55mm Polyurethane Insulation
Stainless Steel Cabinet, hinges, latches
Removable Lid
Voltage Cut Out is Factory set at 10.8v DC
$999.95
In order to prevent deep discharge of the battery supply all coolers are equipped with a battery monitor. This can be set via the control panel or the remote control in three stages between 10.0, 10.7 or 11.8 volts. When falling below the voltage, the cooler is turned off. Thus, damage to the battery can be avoided by deep discharge.
Hey did you ever build those 200 series bumpers? Awaiting with bated breath....
