Cost to repair hatch rust?
Idaho
I'm considering (purchase of) an LX long-distance that has rust in the upper tailgate. Otherwise the car is generally rust-free and photos from the underside, engine bay, under tailgate flap etc show no other concerns at all, it is actually pretty clean. I've done some searching here and I gather that the problem is common and is caused by the failure of 3rd brake light seal. I understand that when the problem is serious the hatch gets replaced. Also I see that some of you have valiantly attempted DIY repairs. I am not interested in either of those solutions but I am curious what it would take to have it professorially repaired. Has anyone had this done, or received quote for same? Seller seems to think it wouldn't cost much but we know that goes.
Thanks
They all rust. Even Texas 100s that haven't touched a grain of salt. There is wiring on the inside of the tailgate that is wrapped in a cloth tape and touches against the metal near the license plate on the inside. Soap from a car wash will get into the cloth tape and cause rust to form on the inside of the tailgate. I had to have that section of metal cut out and a new section welded in with some bondo and whatever to took to reform the metal.
Most do not have rust. Find parts rig without rust. Swap out.
My 06 is completely rust free without even a spec. Since this is generally not the first area to rust, I would do a much more thorough check of the underside, especially to check the rear members. I wouldn’t buy anything that’s been painted or coated or fixed.
If you truly only found rust on the hatch (which I honestly think is highly unlikely), it’s probably less expensive to buy a used hatch with zero rust.
It's not painted or coated or fixed. It's a clean California car with no underside corrosion. The rust in the hatch has nothing to do with road salt, it is because of leaks as described by @OwnerCS. This is a common and thoroughly discussed issue.
Back to my original question: I'm not interested in replacing the hatch. Can it be fixed by a body shop? Or should I pass on the car?
I could get it fixed. It would take some cutting and welding in a new area. I have a buddy who can do it.
Yes it can be fixed by a shop either by cutting the rust portion off and rewelding a new piece section or bondo after treated.
Just ask for quotes from an auto body shop in your area. Depending where you are, prices will varies from states to states. In CA bay area that might be a $1500
But finding one to match your color, your patience will be tested. Or repaint the new hatch to match will also be $$
you also need to wonder how much more rust in inside that hasn't come thru yet. you currently see a small area but it could easily be 4-5 times that
yes it can be fixed/repaired, if cost isn't an issue
if cost is an issue, that is where the replacement comes into play
OK, you are right. Considering I’ve had two of these that would conflict your statements rust doesn’t just appear, it comes from neglect. Whether it is somebody neglecting washing it or whether it is somebody neglecting putting a brake light in or whether it is somebody neglecting fixing a spoiler that is leaking, it’s neglect. A body shop can tell you they can fix anything. Good luck, I hear that rust is not like cancer and is very easy to fix permanently and long-term….
What was the selling $? And what yr?
It was a 2000 and the price was about 17k with about 200k miles. 1 owner, clean and unmessed with- just what I've been looking for. Went quick, guess I should have bought it. Between the rust concern and the travel that would be required to get it I drug my feet. I feel like I've been searching for one of these things forever, maybe its just not meant to be.
Interesting to the (hatch rust) topic, there is a 2000 LX on BaT right now, not nearly as nice as the one I was looking at but still a Cali car, and it has the same issue. Seller just added photos showing the rust (go to the comments to see).
Living in Idaho, I'd skip any 100 with rust, you have the benefit of nice dry rigs up there. I have a great friend who lives in Mountain Home who's had a half dozen 100s (maybe more by now) and there's never been any rust on any of them.
I don't know where he finds them but no LC is a common car here. Salt Lake maybe, but those typically have some corrosion. But again, the car in question had zero rust from road conditions.....it is from the leaking hatch and if it can happen in SoCal it can happen anywhere.
