I have a 69 fj40 and would like to add power brakes. I'm sure there are many different options out there. Which would you guts suggest with cost and effectiveness in mind?
My question is have you gone thru your brake? If you haven't just adding a booster probably won't solve all your problems. Once I when completely thru the brakes on my 68 they worked fine. Can lock all four wheels and doesn't pull to either side. If you determined to add a booster I won't waste my time unless you go all the way and add disc brakes up front and switch to dual circuit 10MM brake lines.
I did find this at Man a free. Tandem Brake Master Cylinder Conversion Kit for Pre 7/1970 FJ40/45 - Man-A-Fre
