thatcabledude
GOLD Star
Probably fine. Maybe don’t run the AC and swap the rad soon. Bring enough water for the truck in case you need it.
I was driving offroad up a 6% grade For 2 miles to get to a trailhead today. Ambient temps were about 92F. I was full-loaded with 7 people and some gear and the AC was blowing.
The AC cut out with another half mile to go, so I assumed that the engine temp hit at least 226F. No smoke or steam from the hood. we made it to the trail head and I checked the engine bay and this is what I found...
After the engine cooled a bit, we continued on our way. AC was blowing fine. This normal? Thanks and happy 4th!
We would set up camp (we travel with shelter, food, and water x 1 day for daytrips), and 2 of us would hike back for help. But, point taken thanks!
What mph were you doing?
I've found my motor works up some heat going up grades <40mph.
You've got a full load there, so it can really lug the motor.
Turning off O/D and/or putting it in 2nd helps quite a bit. Bring those rpms up a bit.
I would change out the coolant and road test before your trip, see how it goes.
Seems like the new, cheap oem replacement radiators are a good idea for improved cooling.
Did you do that in D, 4hi, OD on?Was running 10-15mph the whole way up. I've been commuting in the LC daily since. Topped it off once with 16oz of coolant about a week ago and haven't touched it since. Engine is running well and just passed smog. Temps have been around 190-196F with in and around town driving in 110F temps. I'm going to replace the radiator, but covid19 ops are keeping me busy. Looking at the denso unit, but have to do more research. Truck will have to wait a little longer...
If you're fully loaded w people and cargo at that speed, try 2nd, OD off or just put it in 4Lo, D
I think you'll find it much more favorable to your motor temps.
Does that really keep it cooler? Rather than just keeping it in “D”?6% and 92° = 2nd gear if you want to be cool
good to know. Thank you.Should, higher rpm (up to a point is good ) keeps the engine in its power-band, fan is turning faster, water pump moving more coolant (of course engine is turning faster too...but not lugging so much).
I did it in D and OD off. I won't do that again--thanks for the tip! I didn't even think about shifting down because the engine was performing well. In fact, the only reason why I knew it was overheating was because the AC cut out.
As with most crap from them, it's a waste of cash.So I rolled the dice and bought a used brass radiator for cheap online (Cruiser Parts). It arrived today, but I think it’s damaged along the bottom. I’m no expert, but I’m pretty sure the tubing should not be bent like that. Is it repairable?
