I've got my 1hdt running well with a good tune. it is intercooled with an air water intercooler and i have it boosted to max 16psi. i typically run at around 600 to 700 degrees f on a summer day when at highway speed. only have a puff of smoke when shifting gears and otherwise none. i have done the tune up work with the intent of pulling a trailer. now that i have a few thousand km of trailering i wanted to ask about my cooling. i find that if i pull over 90 km/hr or into a heavy head wind my temp gauge (remember its the stock gauge from my gas engine) starts to read between the 2/3 and over heat mark. egt are constantly around 900-1000 while this is happening. short pulls up hills i have lots of power yet and egt get up to 1150 max but settles down once up the hill. it's the overall engine temps that i wonder about my cooling system not keeping up. has anyone else had their engine run this hot after a tune of the pump and boost? my radiator is the stock 4 core fj62 rad that was flushed and pressure tested. one thing i haven't tested is the clutch fan but at highway speeds this shouldn't be the issue. without trailer i have no troubles keeping temps down at the 1/3 mark on my gauge.
thanks for your thoughts!!
