Condenser recomendation (1 Viewer)
Florida
Hello folks,
First time posting!
My A/C recently stopped working and I found the condenser to be the culprit. I almost always use genuine replacement parts but this time around I'm debating whether to go aftermarket. Unfortunately the Denso condenser is no longer available and the original is around $350. I am thinking about ordering an aftermarket from Rockauto. Are there any brands that you recommend or any brands that I should stay away from. Any past experience would be helpful.
I’d recommend Toyota or Lexus if you’re fancy!
I would spend the $350 and put in a new Denso.
There is a CSF unit and Nissens is also a good brand, Most aftermarket units have flaws and quality may not be as good as OEM.
I just had a very reputable cruiser shop in Mesa Az put in a new condenser (and compressor and replaced a line).
They told me the condenser was the last one available in the country (OEM I suppose?). 05LX
On side note, the fitting to the line on the bottom of condenser is leaking oil and there’s bubble/ air boiling in the sight glass.
I assume I should take it back to the shop ?
Yes, I would.
I dropped it off this morning .. he said it wasn’t leaking but replaced the o ring anyways ? Said it was residual from disconnecting . Idk.. I wiped it off really good and saw it puddle right under the fitting.
Maybe I’m being neurotic .. We’ll see how it does after this go round I keep an eye on it
