Condensation Leak inside
Hills of Tennessee
Can you someone direct me to the thread, discussing water on front passenger side floorboard from the A.C.? I am sure it is a tube, pipe, etc. clogged.
Thanks
Grouseman
Grouse,
not sure what thread you are looking for, the ac drain tube is on the outside of the truck. should not be draining inside at all. On mine (92) the tube is just behind the ps frt tire and is about 3/8" outer diameter.
condensation build up inside is more likely the sun roof drains than ac build up.
Dave
Hills of Tennessee
Well the water is collecting at the right front section of the passenger floorboard. So you think it could be the drain for the sunroof? Will check to see if I can find any hoses under the dash tomorrow.
GM
Eric_FJ40
Yuma, AZ
Look for the condensate drain tube on the engine side of the firewall - low on the passenger side. Stick some wire up there and see if you can unblock it.
If it is blocked, the condensate can back up and reveal itself in the area you describe.
I don't have a sunroof on mine, but from what I've read here I think it drains into the rockers through the kickpanel - so the "right front section" of the footwell could also describe that area too.
Eric
TX_TLC
Texas
Thanks
Grouseman
search water, floorboard....or sunroof drains...
ttt :rolleyes:
"Teach a man to fish...."
Beowulf
Somewhere in the foothills...
TTT=Take To Top (or BTT, Back To Top)
When you have forum software that marks new posts to a thread, this is a way for someone to take it back to the top. Generally considered bad form.
-B-
