- Thread starter
- #21
@Solace in Solitude Carb is properly capped at the port. Still concerned about smoke. The primary main nozzle must be responsible for the gas in the upper part of the carb. The compression numbers are not current, but they were low. The vac number seems good. The fuel pump is new.
You mentioned DUI. I'm still semi-electronic ignition. However, I probably should check for dwell on the new dissy, because it could cool my spark if the points are off. The U-groove Denso's from SOR are gapped closer than 2F spec (they have a different geometry).
