I have cold air blowing in from the pass side floor. It is comming from under the dash in the middle. There was a draft from the heater fan box but that was becouse the cabel to change the inside to outside air was off.
I was going to seal up the cold air draft with some insulation stuffed up in that area.
What insulation/foam should I use as not to start a fire?
