Thanks Beo,
I was going through the FSM on Sunday night and was going through the VSV test. In calling for the removal of the air intake I realized why so many folks avoid testing it. I am collecting an order of Dan and was looking for any gaskets I would need just for the testing. I am glad I don't need to remove the air intake though. The only thing that I need to get is a vacuum gauge.
A few questions ...
When you say 'intake cleaner' do you mean something like carb cleaner? Does it really matter?
In my '94 FSM on EG-186:
STEP 3. INSPECT SEATING OF EGR VALVE
Start the engine and check that the engine starts and runs at idle.
QUESTION: This is after putting on the vacuum guage, does checking the EGR valve seating mean that it is in place correctly, clean, not stuck?
STEP 5. INSPECT OPERATION OF VSV AND EGR VACUUM MODULATOR WITH HOT ENGINE
c. Disconnect the vacuum hose port R of the EGR vacuum modulator and connect port R directly to the intake manifold with another hose.
QUESTION: Do you do the hose rerouting while the engine is running?
STEP 7. INSPECT EGR VALVE
a. Apply vacuum directly to the EGR valve with the engine idling.
b. Check that the engine runs rough or dies.
QUESTION: How do you apply the vacuum?
In my '94 FSM on EG-188:
EGR VACUUM MODULATOR INSPECTION
after testing for air passing through the filter with the engine off ...
d. Start the engine and maintain speed at 2500 RPM
QUESTION: Start the engine with all the vacuum hoses disconnected?
Thanks for the help
Ross
A few questions ...
Thanks for the help
Ross
