I just never have a front plate on, but I should really find a plate holder for the front receiver.I think your front receiver is a great idea! It was above our abilities + where do you put your front license plate?
Post some pic's when you figure it out!Sorry to bring up an old thread but I just got my Coastal bumper welded and installed the other day. Is the bottom of your grill attached to anything. The only thing attached is the top part of the grill. My bottom grill basically flaps around. Im afraid that it’ll just fly off after a while. Lol. Is there a fix to this?
I assume you had to remove the horizontal metal brace behind the grill? For my Victory that brace stays in place, along with the plastic "pockets" the grill ties into. You can see the horizontal brace in this picture.Sorry to bring up an old thread but I just got my Coastal bumper welded and installed the other day. Is the bottom of your grill attached to anything. The only thing attached is the top part of the grill. My bottom grill basically flaps around. Im afraid that it’ll just fly off after a while. Lol. Is there a fix to this?
I found the horizontal base but I think I need to fabricate something to hold the tabs in place. The original tabs are built in the oem bumper cover.I assume you had to remove the horizontal metal brace behind the grill? For my Victory that brace stays in place, along with the plastic "pockets" the grill ties into. You can see the horizontal brace in this picture.
If that brace is gone, I would suggest creating a brace from the grill to the vertical brace in front of the condenser. You might be able to utilize this piece that went between the aforementioned horizontal brace and the vertical brace, but may have to lengthen it somewhat if the horizontal brace is gone. Or make a new one. And, of course, you will have to figure out how to tie it into the grill.
Here are the pics of the grill installed. The bottom tabs are circled.Post some pictures of it installed. I will be glad to give your some quick fab ideas . I put on the Victory4x4 on my 13 GX and they sent button head screws to attach the grill and cover to the bumper. Put the pictures up .
Mine is a 2018.I found the horizontal base but I think I need to fabricate something to hold the tabs in place. The original tabs are built in the oem bumper cover.
What year is your gx?
Sounds like a plan. Thank you!Try this on a couple of them and see if it feels right. Drill a hole 5/32 thru the through the tab and metal tabs that are over the metal frame. Put a 1/8 zip tie in from underneath.
Then take the head of another exact zip tie and cut the tail off. Slide the head down the tail of the first zip tie til it’s almost tight. This should hold the grill I place. . If it feels good do the others. You can make a plastic tab extension for the tabs that need to be longer. Let me know if this hack works for you. Thanks Anthony
I was thinking about that. I need to really look at the bumper.I can’t wait to see that finished. As you can see most front end parts are really lightweight mounted. Can you cut the part off the original bumper cover and reuse it ? A little flat black paint makes all that stuff look better .
Not really. I did add 2 zipties but I am not sure they are doing any good. It has been that way for 2+ years and the grill seems just as secured as when I mounted the bumper. I can take some pictures later today if that is helpful.Sorry to bring up an old thread but I just got my Coastal bumper welded and installed the other day. Is the bottom of your grill attached to anything. The only thing attached is the top part of the grill. My bottom grill basically flaps around. Im afraid that it’ll just fly off after a while. Lol. Is there a fix to this?
