Wanted Clutch slave cylinder mounting bracket for 72' 40
JustJay
Williams Bay
  1. 40 Series
Williams Bay, Wisconsin United States
Looking for a mounting bracket for the clutch slave cylinder in my 72' 40. I'd attach a photo of one but I'm missing it - hence the ad. :)
To help your search, it should be the one on the left.
To help your search, it should be the one on the left. View attachment 3479812
i offer the disc. / NLA mounting bolts JIS hardware gold zinc plated solution here below
thanks ,
matt
thanks ,
matt
Thanks Matt, I’ll be sure to track you down if I end up looking for those.
Are you using the dash transfer case shifter or is yours floor shift?
Special bolt required for the dash shifter and support bar.
Did you get this figured out yet? I do have one of the brackets and the corresponding motor mount. Pardions pic shows both brackets. Do you have a return spring?
I was in similar situation when i rebuilt my '67 a couple years ago.
Returned your voicemail.
Thanks for following up. Mark took care of me today so I think I've got everything I need. Glad to hear your rebuild of the 67' went well.
