As anyone had immediate failure when installing an aftermarket clutch slave? Got mine from Cool C. and finally thought I would install after repeated bleeding then reoccurring clutch engage/disengage problems. Did not buy and replace master as it looks new (from PO and brake master reservoir also appears identical) based on the reservoir color - white vs. aged yellowish color. No leakage anywhere.
Changed clutch slave, bled extensively with MityMite and adjusted pushrod to match old slave. As soon as I depressed clutch pedal the slave seal failed and leakage occurred at pushrod end.
Any suggestions for next steps? Just get the OEM slave or is there a higher quality aftermarket? I've read other related posts and success reported with Beck Arnley and NAPA.
