Looking for the size of bolt for the clutch flywheel on an 82 fj60. Thanks
Recommend OEM for these critical bolts:
90913-01016
So you're installing a 3FE from a later FJ62 or from an FJ80, right? The early 3FEs use the same diameter (10mm) flywheel bolts as the FJ60s. The later 3FEs used 11mm bolts.Most definitely. I'm switching over to a 3fe and I need the holes drilled out but can't find the bolts at the moment and was hoping someone could help me so I know what size to make them
