Yes new noise he drives the rig for 10 years all ready
From his very first post:
"I’ve had this clunk noise for quite some time now."
To the OP:
Since you went through the front end an rebuilt it and did not have any true results, and you state: "It's more like a heavy metal hitting another metal instead of a clunk."
Assuming it's not the "normal" first to reverse clunk (because it takes up ALL driveline slack from one extreme to the other....)
If you don't get the high pitched "ding" when you do it, then it's less likely to be U-Joint.
Then I would lean toward:
Transfer case play from input to output
Transfer case play front output to rear output
Possible loose pinion bearings front and/or rear
Check the transmission and engine mounts for play
Check the amount of rotational play (by hand with the engine off, wheels chocked, trans in neutral, T-Case in Hi) by grabbing the front DS and twisting from full left to full right and estimate the TOTAL number of degrees of rotation betweeen loose play, light contact play, and hard stop. Do the same with the rear DS.
Loose play will be free rotation between the slightest contact internally. This will be the pinion to ring clearance. This should only be 1-3 degrees.
Light contact will be make the contact to one side of the ring, then rotate more until you feel the next resistance. This could be the front drive flanges to the axle to the ring gear OR it could be the clearance within the transfer case, whichever is LEAST. This will be about 10-15 degrees total from left to right.
Hard stop will be as hard as you can twist by hand left to right. This will be a few more degrees, 15-20 degrees tops. If you are above these estimates, you MAY have worn drive flanges, worn pinion bearings, or worn internals in the T-Case.
Then you work through them one set at a time starting with cheapest and easiest. Drive flanges.
Check your FSM for more info on each of these and acceptable tolerances.
Also, don't forget to grease your u-joints and yokes. Do this when the drive line is UNLOADED as I described above.
Hard stop
