So. I have a clunk. Or kinda more of a twang. It seems sorta delayed though on P to D or P to R. I haven’t lubed anything yet just learning bout these things... it doesn’t super annoy me yet I was just making sure it wasn’t something serial
I think I see what you did with that song. Replace clunk with funk? Diiiiigit!
Something it doesn't state in this thread about the clunk:
Check your drive line when it is UNLOADED.
This means that you have parked your 80.
Set your parking brake.
Place a block on both front and rear of two wheels minimum.
Place the transmission shifter in NEUTRAL.
The Transfer case can be in 4H, N or 4L
Grab each drive shaft (DS) at each end and try to move the end perpendicular to each half of the cross (u-joint) at that end. There should be no discernible movement.
You will do this to both ends of the DS in two directions on each DS. This means you will do this 8 times.
Then you also check rotational movement INDEPENDENT of the flanges bolted to the DS. This is ROTATIONAL and is done by twisting the DS by hand. You should see no movement in relation to the FLANGES or YOKE. (Yes, you will see SOME rotational movement due to the gap in the ring and pinion teeth. There should be no more than a few degrees of rotation, not "inches" of rotation)
Lastly, you will try to move the shaft PERPENDICULAR to the shaft itself, near the slip yoke. This is to see if the splines are worn to the point that the DS is "drooping" because there is so much slop in the splines that it binds where the two pieces slide together.
When you're done checking for excessive wear, grease the DS U-Joints, Slip Yoke, and steering components while you're there. All greasing should be done with the vehicle in NORMAL POSITION (not axles hanging from a frame supported by jack stands) because then the grease will be placed in the area of NORMAL operation and the system unloaded.
I use Lucas Red-N-Tacky 2 for the U-Joints, and Valvoline Palladium (Moly) for the slip yokes and tie rod ends. YMMV
