- Thread starter
- #41
This I'm not quite sure of. The engine came out of a parting out vehicle, so the details are scant, but it was at 9 degrees when it was pulled and as the mechanic was tuning up everything once installed he said it didn't run well at 9 degrees, so he set it back to 3. So, you guys are right, if it wasn't right at 9 when that's how it was when it came out then something else was going on.This stands out to me. Why was the engine orignally at 9 degrees and had to be bumped back to 3, I'd double check timing following the FSM and make sure it is within spec. And if it's not adjust it so it is, and if it runs worse than something is going on there.
I'm going to start on this tomorrow and also look into the IAC issue mentioned in another response. Thanks guys!
