Vitesse_6 said:Im very disappointed....I went to my local BG dist. which is about 1 mile away, $70.00 !!! !
I will see IF I need it that bad....
Thanks for the info.
elmariachi said:$25 total from BG Products.![]()
EVAPORATOR
INSPECTION
1. REMOVE EVAPORATOR (See page AC–25)
2. CHECK EVAPORATOR FINS FOR BLOCKAGE
If the fins are clogged, clean them with compressed air.
NOTICE:
Never use water to clean the evaporator.
3. CHECK FITTINGS FOR CRACKS OR SCRATCHES
Repair as necessary.
4. REINSTALL EVAPORATOR (See page AC–25)
RavenTai said:Maybe they mean wile the evaporator is removed and open (see context) you should not use water on it in fear of getting some in the open ports? Water contamination on the inside of the system is a problem. On the exterior of a sealed evaporator should be fine,
Interesting to hear that the AC now seams t work better, if it was covered in funk before it would make sense that it will cool better with that insulation removed.
Arleaux said:Any chance of a group buy?
hkimsoft said:...kit which comes with an Evaporator cleaner and refresher from "PETRO Checmical A/C Power Foam". This is what they use on Toyotas for A/C service according to the parts rep.
hkimsoft said:(...)
Then follow with "ConditionAire 2005 Refresher" into the fresh air intake with blower on high...
I see.Grench said:The slots in front of the hood next to the wipers I believe.
Grench said:I have no idea. My only trick with the fresh air intakes is to put the 2nd row floor mat carpet side down over them and under the wipers when its going to snow. It helps a lot to keep the inside defogged if the intakes aren't sucking frozen water or clogged.
