Hey everybody, I have a FJ60 with a stroker 383 and a TBI injection setup. I am at a lost and have done multiple searches on the web and forums and cannot find the exact situation that I am experiencing. I have gone through all of the timing procedures (disconnect the ESC wire, set base timing, disconnect (-)battery cable etc...) to get this thing dialed in and have come up with some interesting questions that I'd like to figure out:
1) When setting the base timing, I have to advance the dizzy so that my timing mark on the crank no longer hit the degree marks on the timing cover - if I were to guess, this is in the neighborhood of 20+ degrees advance. The question here is, why does this thing run like it is supposed to performance wise than at the 0 degrees that the factory states for base timing?
2) When the timing is set to "best sound" of the engine, why am I running super rich?
Outside of pulling the engine apart to figure out what the cam profile is, or to see if someone degreed the cam when they built it, what do you think my options are? (I have a coolant temp sensor on order and have checked the resistance on all other sensors and have checked the idle air control).
Thanks in advance!
Thanks in advance!
