Changing out the AHC suspension fluid? (4 Viewers)
While going from high to low or visa versa, are there supposed to be air bubbles that release into the reservoir tank right as the pump stops running? I cycled the ahc system between low and high at least 4 times with this still happening even though everything seems to be working fine.
Not air bubbles, but there is a little squirt of released pressure each time the pump stops.
Does anyone have the part number for the rubber nipple covers?
Was doing a fluid change and due to age / dry rot, One of mine disintegrated.
Did an AHC fluid refresh on my 06LX yesterday. Used up all 2.5L AHC fluid in the can and level in the reservoir is right at “Max”. This is after I bled all 4 bleeder valve and new pink AHC fluid came out.
