Spark plugs in more detail. Sadly out of order at this point so no way to match plugs to cylinders.
All six of those plugs look good. Light tan, maybe running SLIGHTLY lean. Do you have any exhaust leaks?
What year since it's not in your sig line.....?
Also, I would seriously look at the valve cover gasket, spark plug tube seals, PCV grommet and valve, and distributor O-Ring. Also get a new oil fill cap.
All of these items contribute to drawing in unmetered air into the engine, which picks up oil on the way in, and burns it as well as causes it to run bad. The computer will adjust to compensate to an extent.
So, spark plug tube seals will leak air, pick up oil, and then the engine sucks that air through the PCV into the throttle body, thus burning a lot of oil.
If you unscrew your oil fill cap while idling, the engine SHOULD almost fall on it's face and run very rough. If it doesn't then the computer is already adjusting for massive vacuum leaks.
Now for the possible bad news:
Watch the compression on #5 and 6. Those are the known areas for the HG to blow and it will frequently take out #5 and 6 at the same time because it will blow between them.
Get a Blackstone oil analysis to determine what's happening and if there is any coolant making it to the oil or other contaminants in your oil.
