SOLD Central Ca: 1994 80 series, lockers, white all stock (1 Viewer)
Year
1994
  1. 80 Series
Bakersfield, California United States
Mileage
219699
Color
White
Posting this for a local friend. I did all of the work on it recently probably within 500 miles. Runs really good no problems there.
Maybe some slight surface rust underneath but it's been in CA for a long time.
Looks like the front driver fender was repainted at one time, driver mirror has been replaced. Clean title
$16,000
219k miles. Factory Lockers
Cold AC
Both front seat gears were replace
Both front seats new upholstery with center armrest
New Shifter cover
Door courtesy switch on passenger side
Tires in good shape with fresh alignment.
Rear emblem is getting put back on
Fresh oil change
Work I did to it:
Knuckle rebuild including bearings
Valve Cover Gasket
Throttle body gasket
Spark Plugs with tube seals
PCV Valve with Grommet
Valve Cover Vent hose #1 & #2
Oil Pump Gasket
Front Main
Rear Wiper nozzle replaced
Diverter valve for front/rear nozzles replaced
Bad:
Engine light code 71 comes on intermittent. Has recently passed smog while it was off.
Small windshield leak he said a little water gets in on driver side while going through auto car wash dryers at the end.
Couple small dings on the body shown in pics
Check the VSV’s under the intake manifold. Mine was bad changing Egr didn’t fix code. Also check the ports on the manifold as they can get clogged.
